How to assigned network type based on voltage value in FME?
  • Apr 12, 2016 3:07 PM UTC
  • 58 views
I am using FME for migrating ESRI shape file data into Smallworld.
I want to assigned Networktype based on Voltage field.
I want give network-type based on Voltage value Ïf voltage is "386.00KV,154.00KV" NetworkType is HV,If Voltage 36KV, 15.8KV, 6.3KV then networkType is LV.
How can i give this in FME using transformers.
Thanks in advance for your help.
  • Apr 13, 2016 3:26 AM UTC
Hi @mahendra30627, there are several ways. Just an example, you can use the AttributeCreator with conditional value setting.
Thanks takashi
  • Apr 13, 2016 9:26 AM UTC
I'd also look at the AttributeValueMapper as I've seen previously the the conditional value can be slower in some circumstances especially processing larger number of features.
