How make an ecw with different information to different scales?
  • Feb 14, 2013 9:18 AM UTC
  • 8 replies
  • 72 views
I'm trying to generate an unique ecw file, which contain at different scales, different information.
For example:
- at 1:100.000 a map
- at 1:50.000 an satellite image
- at 1:10.000 aerial photography
Know anyone how to do it or if it's possible with ecw format?
Thank's.
Forum|alt.badge.img+63
I don't think that's possible in the ECW format.
sigtill
Forum|alt.badge.img+25
  • Feb 14, 2013 4:39 PM UTC
Dont think this is possible. Where are you going to use this data? In an online mapping portal or as a regular file on a disk?
  • Feb 14, 2013 4:58 PM UTC
Hi, Yes we have this done in the web with different tiles, but now I would like to have a single file to use with desktop applications. And i think i have seen an ecw with multiple information at different scales.
sigtill
  • Feb 14, 2013 6:42 PM UTC
Which desktop application? I suspect that the Desktop application itself "switches" between two or more different ECWs at different scales - however it would be very nice if I was wrong. Havent found anything on Google yet.
fmelizard
Forum|alt.badge.img+22
  • Feb 14, 2013 7:01 PM UTC
What SigTill suggests is correct, its common practice to display rasters with different scale information, by setting the visibility scales per raster.
  • Feb 14, 2013 7:39 PM UTC
Yes, i already know. That's a valid option but I would like to make it With a single ecw file to to simplify the use and avoid configurating the aplications. In fact, I have already the diferents files at diferents scales. The key it's to know if its posible with the ecw format. Thank you anyway
sigtill
  • Feb 20, 2013 9:03 AM UTC
I would suggest to contact ERDAS/Intergraph or whatever name they have changed to :) directly. Please post the answer here when you find it, although I would bet a beer that the answer is no: http://geospatial.intergraph.com/Homepage.aspx
  • Feb 20, 2013 12:04 PM UTC
Surely it is not possible (sorry for the beer), but It could be a great quality for the ecw format. If I get an answer I'll post it.
