How do I set up connection for trainingdatabase
  • Jul 5, 2022 12:20 PM UTC
  • 31 views
Hi I am trying to set up the trainingdatabase and are using the correct credentials that is specified in course. host: postgis.train.safe.com, port 5432, DB fmedata User fmedata PW fmedata. When test i got no answer from server. Tested in cmd and it seems to be down?.. Skärmbild 2022-07-05 141916
kailinatsafe
Forum|alt.badge.img+24
Hello @mr_ene_​ , can you share a screenshot of how you've entered the parameters for the TrainingDatabase please? Also, have you connected to the TrainingDatabase before and now you're unable too? Let me know, Kailin.
  • Jul 6, 2022 6:26 AM UTC
Hi I was running FME workbench from my work computer and later on, I installed FME on my personal computer instead then it worked. Seems like the firewall makes it nogo on port 5432.
kailinatsafe
@mr_ene_​ , glad you were able to connect!
