How do I get my FME output for tif files to be caps e.g. NN00_25kcrm_34.TIF rather than NN00_25kcrm_34.tif?
  • Dec 15, 2017 4:44 PM UTC
  • 5 replies
  • 117 views
Best answer by takashi
Hi @annmarie, a possible workaround is to write the resulting tif files into a temporary folder with the FetureWriter at first, and move them with file name containing capital extension to the final destination folder with the File Copy writer.
[Addition] Instead of the pair of VariableSetter/VariableRetriever, you can also use the FeatureMerger to merge the temporary path to the raster features unconditionally.
  • Dec 15, 2017 5:08 PM UTC
I'm curious, why do you need this? For most systems it shouldn't make any difference.
  • Dec 16, 2017 7:22 AM UTC
  • Dec 18, 2017 10:26 AM UTC
Thank you so much. I'll give it a go.
  • Dec 18, 2017 10:32 AM UTC
Another solution would be to use a SystemCaller after the FeatureWriter with something like:
rename @Value(_pathname)\*.ini *.INI
That way you won't have to use a temporary file location and the filecopy writer.
  • Dec 19, 2017 10:13 AM UTC
This worked really well, thank you. David_r's idea was also good, but unfortunately didn't work for us in this instance, as we needed to fan out into folders.
