How do I control the execution sequence for path/filecopier
  • Feb 7, 2020 10:34 PM UTC
  • 118 views
fpakzat
Forum|alt.badge.img+3
Hi all,
A very dumb question: below part gives me what I wanted which is to copy a file from a folder to another location. But how do I control the sequence so that this part is executed first, and then go to other part of the scripts. I meant both "Path" and "FileCopy" don't have a connector (to connect to previous step or to the next step after these are done).
Best answer by erik_jan
Instead of the FileCopy writer, you could use a FeatureWriter transformer.
FeatureWriter is a transformer that acts as a writer, but with an output port.
In the FeatureWriter you can specify the same as the FileCopy writer.
Hope this helps.
erik_jan
Forum|alt.badge.img+26
  • Feb 7, 2020 10:38 PM UTC
Hope this helps.
fpakzat
  • Feb 8, 2020 4:07 PM UTC
Hope this helps.
thanks, it worked.
