How could i read two polygon from one reader non spatial
  • Feb 17, 2021 1:38 PM UTC
  • 6 replies
  • 107 views
spiderman
Forum|alt.badge.img+7
i would like read two polygon from one reader not only one
so what should i write in WHERE CLAUSE to read two polygons at the same time to execute both ofthem together .
i am not expert in sql ,i am still beginner .could some one help me ?
Thanks in advance
alexlynch3450
Forum|alt.badge.img+16
Firstly, non-spatial mean no geometry. however, polygon geometry is implying spatial.
So maybe the where clause is not your problem: change reader to a spatial sql source.
But regardless, use 'where = *' as a wildcard and take all.
spiderman
  • Feb 17, 2021 3:30 PM UTC
thanks,i have changed it to spatial but is it possible to read only two polygon from all polygons directly from reader ; i do not want to export all polygons . i want to specify only two polygon
thanks for help
alexlynch3450
thanks for help
SELECT * where [objectidfield] = [xx] or [objectidfield] = [xx].
I would read them all and use a sampler transformer. Or if you know the database and the row's id then you can use similar statement above.
spiderman
  • Feb 17, 2021 5:52 PM UTC
thanks for help
thanks for reply . i got it but i have still problem .
when i use SELECT * where [objectidfield] = [xx] or [objectidfield] = [xx]
i show only in quicktranslator only one row id to enter ,it does not show me two empty field to enter two row's id
only one empty field
my target
when i want to use quick translator ,i would like to write two row's id in quick translator then the workbench works to export it .
at inside workbench what i tried to do ,i used apply to for one of user parameters set where clause and connect it to the reader of polygon
and i created another user parameter with another name and connects to the same reader where set clause .i found ,reference at first user parameter will delete after i connected to the second user parameter at this reader .
should i create two user parameter or is it possible to do with one user parameter ?
i am new in fme and i am confused ,how could i do this process .
Thanks for help
alexlynch3450
thanks for help
step 1 add sql reader and select table in parameter; press ok
step 2 in workbench, double click on feature type
step 3 locate where clause and open text editor
step 4 pull down database tables tab
please utilize FME's resources such as this: https://www.safe.com/training/recorded/introduction-fme-desktop-2020/
spiderman
  • Feb 18, 2021 12:10 AM UTC
thanks for help
thanks alot . it works and i will watch the video .
