How can i transform Bently .dgn BIM model to multipatch.GDB File ?
  • Oct 22, 2018 1:44 PM UTC
  • 75 views
ganesan
Participant
jovitaatsafe
Forum|alt.badge.img+11
Hi @ganesan,
Thanks for your question! In FME 2019 (the beta version), you should be able to add a DGN (V7 or V8) reader and connect it to a File Geodatabase writer. Make sure to set the parameters of the writer to Geometry: Multipatch. You can install the 2019 beta version.
In order to use the File Geodatabase writer though (File Geodb), you must have ArcGIS installed on the same computer as FME. Let me know how that goes for you!
