How can I test CityGML attribute's value?
  • Jan 3, 2016 10:23 PM UTC
  • 48 views
I have a CityGML dataset that I want to test if its value is not in a range of values (codelist). There are generic attributes that are easy to test with the Tester transformer. These look like this:
<gen:stringAttribute name="DatenquelleDachhoehe">
<gen:value>1000</gen:value>
</gen:stringAttribute>
<gen:stringAttribute name="DatenquelleLage">
Others look like this:
<bldg:roofType>3100</bldg:roofType>
<bldg:measuredHeight uom="urn:adv:uom:m">7.808</bldg:measuredHeight>
<bldg:storeysAboveGround>2</bldg:storeysAboveGround>
How can I test these attributes? Thx
erik_jan
Forum|alt.badge.img+26
  • Jan 4, 2016 5:46 PM UTC
I would create code lists in for example XLS or CSV.
Then read both the code lists and the CityGML into a FME Workspace and use the FeatureMerger transformer to merge both datasets.
All not merged features from the CityGML dataset will have a value for the tested attribute that is not in the code list.
Hope this helps.
  • Jan 10, 2016 11:11 PM UTC
@erik_jan Thanks for the hint. I have done it now with a Tester. I can only test the attributes which look like name="DatenquelleDachhoehe"> and value>1000<. Does anybody know how I can test this attribute <bldg:roofType>3100</bldg:roofType>? Normally I need a name and a value to use the Tester. I need a workflow that replaces the value for roofType when the values is not in "1000,2100,2200,3100,3200,3300,3400,3500,3600,3700,3800,3900,4000,5000,9999" with "values is incorrect". Does anyone have any idea?
