How can I prevent FME from creating blocks when exporting polygons with holes to DWG?
  • Nov 26, 2015 4:16 PM UTC
  • 135 views
Dear users, I need to convert polygons from an ESRI filebased geodatabase to AutoCAD DWG. Unfortunately FME creates blocks for all polygons that have holes. My question is: can I prevent FME from doing this or is this absolutely necessary when using the AutoCAD file Format? Thank you very much in advance.
fmelizard
Forum|alt.badge.img+22
  • Dec 1, 2015 7:18 AM UTC
From http://docs.safe.com/fme/html/FME_ReadersWriters/FME_Readers_Writers.htm#acad/ACAD_writer.htm, I find:
Prefer Writing Donuts as Hatches
This parameter can be used to change how donut geometries on features with autocad_entity attributes not set to autocad_hatch or autocad_mpolygon, are represented as AutoCAD entities.
If this parameter is set to Yes, and a donut is planar, then it will be written as a hatch entity. Donuts with three dimensions will only be written as hatches if they have a constant Z value, which can be stored as the hatch elevation.
If a donut is not oriented in the XY plane, then the feature must have autocad_extrusion_x, autocad_extrusion_y, and autocad_extrusion_z attributes set which indicate the normal vector direction, orthogonal to the plane of the object. If not, the hatch may have Z values dropped, to force it into the XY plane.
If this parameter is set to No, or a donut is not planar, then that donut will be handled like a multi-area geometry, and will be written as a block.
fmelizard
Note -- this is because the DWG format doesn't have a primitive type for polygons with holes. So we have the choice of either making a block, or going the Hatch route.
Hope this helps.
  • Feb 1, 2018 2:48 PM UTC
Sorry for posting in an old topic. But i have exactly the same problem. 'Prefer writing donuts as hatches' option yes gives me a lot of filled polygons/hatches. I like to have them transparent, in line with the drawing.
The option no gives me a lot of extra blocks. No option for me.
So is there any option to write the donut polygons in a normal way?
