How can a Reader starts after Writer is finish
  • Feb 21, 2017 4:25 PM UTC
  • 5 replies
  • 302 views
jtn40764
Participant
I have a question. I make a Projekt in FME Desktop and I want that a one of the Datareaders starts after a writer has finished his work. Is this possible? I need this, because the writer updated a table from the Reader
Best answer by jdh
In that scenario you probably want to use the featureWriter/ featureReader transformers
jdh
Forum|alt.badge.img+41
  • Feb 21, 2017 4:28 PM UTC
Forum|alt.badge.img+54
  • Feb 21, 2017 7:04 PM UTC
You will need to consider that sometimes, a featureWriter can report as finished whilst still writing to a file/database.
itay
Forum|alt.badge.img+19
  • Feb 22, 2017 8:07 AM UTC
I would use the exiting summary feature to verify via sql that all is written before continuing and reading.
  • Feb 22, 2017 9:21 AM UTC
The exiting summary can be written prior to all the features actually being written, particularly if writing to something like Oracle. Just something to be aware of, I always use an sqlexecutor to check the rowcount and only continue the workspace if this matches the written features in the exit summary
jtn40764
Participant
  • Participant
  • Feb 22, 2017 12:18 PM UTC
Thank you for the help. I will add a sqlexecutor to check the oracle db.
