Hi, the doc for Trimble Sketchup says version 2015 or earlier is supported, so 2016 and later are not supported?
  • Aug 11, 2020 7:20 PM UTC
  • 31 views
bruceharold
Forum|alt.badge.img+19
rahulsharma
Forum|alt.badge.img+12
Hi @bruceharold​
As mentioned in the documentation, this is correct. This is the version of Trimble Sketchup that FME is able to read and write. So if you have a sketchup file with a newer version of Sketchup, its most likely that FME will not be able to read and our writer will only be able to write Version 2015 or earlier.
