hello everyone, I have a CSV file or a dgn file and my attributes input change every time. So I want to apply to them a default attribute name (rename them); The first image is an example of what I don't want, the 3th image is what I want in defau
  • Feb 24, 2022 10:05 AM UTC
  • 35 views
imageI have tested different transformer and way, but I don't understand how to apply an input in order.
  • Feb 24, 2022 11:26 AM UTC
Hi @mathis​ , if the order of the attributes is identical always, you can read the CSV file using the default column names (col0, col1, col2, ...) with this CSV Reader parameters setting. You can then rename them appropriately.
csv-reader-parameters
  • Feb 24, 2022 12:38 PM UTC
thank you @takashi ! as i do not yet know the tools well, I went a little far for nothing.
