Has anyone tried using FME 2017 with AGOL services with HTTPS turned on?
  • Aug 16, 2017 4:40 PM UTC
  • 44 views
We recently had HTTPS turned on for our AGOL site and now cannot access layers in feature services in FME 2017. Has anyone else had this experience?
carsonlam
Forum|alt.badge.img+7
  • Aug 17, 2017 6:26 PM UTC
I'm not aware of any known issues here. Can you share the error message you're getting? Are you using ArcGIS Online specifically, or an internal Portal instance? Thanks.
  • Aug 17, 2017 9:15 PM UTC
I actually reported this to support and have someone working on it. @carsonlam I just wanted to see if any other users were experiencing this problem. The problem is on AGOL in the cloud.
the message window displays the actual error. This error happens for both the portal reader and the feature service reader. It is related to us turning on https because this worked before that.
carsonlam
  • Aug 17, 2017 9:34 PM UTC
Thanks, I just spoke with Annabelle about this. We're working on it.
