Group by and write to database
  • Sep 18, 2020 10:27 AM UTC
  • 88 views
achilles07
Participant
I have a postgresql table pre_val_error with following fields
GRID_ID|ERROR_LEVEL|ERROR
121|1|ERROR1
121|2|ERROR2
121|3|ERROR3
The requirement is to write all the records to a csv file and insert a record in Oracle with count grouped by error_level. The Oracle table details are below
GRID_ID|ERROR_LVL1_COUNT|ERROR_LVL2_COUNT|ERROR_LVL3_COUNT
121|1|1|1
As you can see, the number or records has to be grouped by error_level and inserted in Oracle. I have tried aggregator, counter and nothing worked. Can anyone suggest a solution for this problem.
Best answer by takashi
Hi @achilles07​ , I think this workflow generates your desired result.
workflow
  • Sep 18, 2020 11:09 AM UTC
Hello achilles07,
For the stats (counts) - use the StatisticsCalculator Transformer
GroupBy: GRID_ID
Analyse: ERROR_LEVEL
Output - look at the _count attribute
To Pivot (data into fieldnames) eg the different ERROR_LEVELS
Take a look at AttributePivoter Transformer
Hope this helps / gives u some ideas
Howard L'
  • Sep 20, 2020 12:10 PM UTC
workflow
achilles07
Participant
  • Participant
  • Sep 20, 2020 12:13 PM UTC
Hello achilles07,
GroupBy: GRID_ID
Howard L'
Thanks for the suggestion @howard_l​ . StatisticsCalculator is still returning more than 1 feature. I was able to solve it with the help of aggregator and generating a list out of it.
achilles07
Participant
  • Participant
  • Sep 20, 2020 12:14 PM UTC
wow @Takashi Iijima​ that was some timing. Let me try your solution also.
