GoogleGeocoder FME 2012 or 2013
  • Jun 4, 2014 2:01 PM UTC
  • 7 replies
  • 90 views
francis_m
Forum|alt.badge.img+9
I want to use the FMX GoogleGeocoder but when I open it in workbench It say that my "AttributeCreator" doesn't have the right version (in FME 2013) and if I try it in FME 2012, It says my HTTP fetcher is not right too.
I need to build back the attributcreator for the "GG_FullAddress".
Any Idea how is the syntax?
thanks
  • Jun 4, 2014 2:31 PM UTC
according to the transformer description, the GoogleGeocoder requires FME 2014:
David
francis_m
  • Jun 4, 2014 2:34 PM UTC
I know but when I place it in my FME 2013, I need to replace an attributeCreator and I dont have the parameter for the AttributeCreator.   Any Idea? can you tell me whats is created by the AttributeCreator, I'm shure I can re-create the same with FME 2013... AttributeCreator is not a transformer very very special!
thanks!
  • Jun 4, 2014 2:45 PM UTC
Hi
I'm not quite sure I agree with your assessment of the AttributeCreator, it has some very interesting functionality (multiple feature attribute support) that was introduced in, you guessed it, FME 2014 :-) But of course it isn't a given that these new functions are used here, only an in-depth analysis of the custom transformer could tell.
I suggest you install FME 2014 ( it is no problem to have several versions installed on the same pc as long as you install to separate directories) and have a look at it to evaluate the feasability of back-porting it to FME 2013.
David
francis_m
  • Jun 4, 2014 2:59 PM UTC
Install FME 2014 - not an option here...  Big Business, Big TI, No admin for me.
If you could just have tell me what the attributecreator create for the "GG_FullAddress"...
That would be nice!
  • Jun 5, 2014 9:28 AM UTC
here you go.
David
francis_m
  • Jun 5, 2014 1:10 PM UTC
Thank You David!
It works in FME 2013.  I have a last demand on this :
I still need another Transformer to "adapt" into the GoogleGeocoder :
I need the AttirbuteCreator for the "encodedsignature" !
Can you do the same again!
Very appreciated, thank you!
I have a google key and like to use it too.
Thanks again!
  • Jun 5, 2014 1:56 PM UTC
that's easy, "encodedsignature" is set to an empty string. The value for this attribute is set in the following PythonCaller.
David
