glTF from FME cannot be verified with Khronos glTF validator
  • Nov 8, 2017 2:55 PM UTC
  • 49 views
After I generate the file using the glTF output writer, and tried the Khronos glTF validator it presents me with errors.
Not sure if anyone else has this problem. In addition, I cannot load using Cesium or threejs glTF loaders.
xiaomengatsafe
Forum|alt.badge.img+11
Hi @vincentsoh, Thank you for reporting this issue. We'll likely need to investigate this in more detail, would you be able to submit a case through https://www.safe.com/support/report-a-problem/ and include the source data and workspace that was used to generate the output? We'll have an expert look into it further. Thank you!
