get numberrecords and filesize
  • Mar 5, 2019 9:28 AM UTC
  • 6 replies
  • 123 views
I would like to detect from a postgis database the number of records and the filesizes (mb) of the tables in a schema so i can write it to xlsx.
I can't find the solution.
  • Mar 5, 2019 9:40 AM UTC
You can get the number of records with a count() in an SQLExecutor, e.g.
select count(*) as record_count from my_table
Expose the attribute "record_count" which will then contain the number of records in my_table.
Concerning the file sizes, which file sizes are you referring to? External files referenced in the table, or the table contents itself?
  • Mar 5, 2019 12:38 PM UTC
The table contents itself. I have tried your solution with select count(*) but it gives an error that my_table not excists. If i specify de schema and table then it works OK.
Is there maybe a wildcard, that makes it possible to count the records of all of my tables?
  • Mar 5, 2019 12:53 PM UTC
Exactly, if you query a table that isn't in the login user's default schema, you will have to specify the schema.
  • Mar 5, 2019 12:55 PM UTC
In an SQLExecutor, try the query listed under "General Table Size Information" here:
https://wiki.postgresql.org/wiki/Disk_Usage
It will give you a lot of information about all the database tables, including estimated record counts and table file sizes.
  • Mar 5, 2019 12:57 PM UTC
If you require accurate record counts, you can try the query suggested here (it may be noticably slower than the estimated record count):
https://stackoverflow.com/a/38684225/10661889
  • Mar 5, 2019 4:02 PM UTC
Thank you very much.
