GEODATABASE_SDE reads lines as IFMELine + IFMEArc
  • Jan 15, 2020 9:46 PM UTC
  • 107 views
Hi, I used to read my ESRI database with the ArcSDE Legacy Reader which worked fine. When I switched to the new GEODATABASE_SDE reader, my ESRI lines that have a cross over that looks like an arc are now read as an IFMEPatch which is a combination of an IFMELine and an IFMEArc.
With the Leagacy reader the same line is read as a Line and not as a path of a line and an arc. Is there a way to force it to be read as a line as before? If not possible what would be the best way to convert it as a line?
Thanks,
Simon
Best answer by bwn
Had the same issue when converting my Workspace from the Legacy SDE Reader.
Tried a few variations, but here is what seemed to work best. Many thanks to @takashi for pointing me in the right direction on how to dissolve Paths with GeometryRefiner! I had previously been using PathSplitter and LineCombiner as suggested below, but replacing it with GeometryRefiner works much better and handles it with less errors.
erik_jan
Forum|alt.badge.img+26
  • Jan 15, 2020 10:03 PM UTC
Have you tried the GeometryCoercer transformer to set it to fme_line?
Hope that helps.
@simonbelletete I think you'll have to use the PathSplitter, ArcStroker and LineCombiner to rejoin all the segments.
example workspace (2019.2): pathstroker.fmw
ArcStroker + GeometryRefiner works too.
bwn
  • Jan 17, 2020 1:01 AM UTC
