GeoDatabase Fanout, Spaces in name
  • Aug 20, 2014 6:44 PM UTC
  • 106 views
I am using the GeoDatabase Writer. I have no other option but to use a specific name field for the Fanout properties. I was having writing issues and I figured out that it is because these attributes have Spaces and it is causeing the problem. Is there any way I can have it eliminate these spaces in the name or replace them with Underscores? Thanks. Here is my log file.
http://pastebin.com/EsSyBEQx
Best answer by fmelizard
You can use the StringReplacer on multiple attributes and there is no need to use regular expressions, just use a blank space as text to match and an underscore as replacement text.
fmelizard
Forum|alt.badge.img+22
  • Aug 21, 2014 7:04 AM UTC
Simply use a StringReplacer on the attribute contining the fanout name.
If you have many attributes with spaces in them, the BulkAttributeRenamer is much more convenient. The logic is the same, but you can process a whole bunch of attributes in one transformer.
... And I was pretty sure there would be a a generic "replace whitespace" option out of the box, but I can't find it in the documentation...?  Of course, you can do anything with regular expressions, but those are intimidating for the unenlightened.
If you have to use regular expression, the \\s (backslash and "s") is regex-speak for "whitespace", and that goes into the "Text to find"-box.
fmelizard
  • Aug 22, 2014 12:55 PM UTC
