FME - why is tif writer is setting 0's in any band to NODATA?[ e.g. (0,16,0)>>(NODATA, 16, NODATA) ]
  • Apr 19, 2014 10:53 PM UTC
  • 53 views
makt
I'm reading a geotiff and am unsure why when I'm writing to a new geotif, all my dark dark green cells, such as RGB (0,16,0), get rewritten to (NODATA, 16, NODATA).
Using the RasterBandNoDataRemover does fix the problem, but also changes the NODATA cells that I want to be NODATA into balck (0,0,0).
How can I fix this? Seems to me that this should not be a default behavior...
  • Apr 20, 2014 9:18 AM UTC
Hi, the RasterCellValueReplacer transformer might help you.
Takashi
gio
Forum|alt.badge.img+15
  • Apr 22, 2014 9:29 AM UTC
Appearently 0 is nodata in your set.
RasterBandNodataSetter or replacer might be usefull.
makt
  • Apr 25, 2014 7:38 PM UTC
After looking over all the options, the easiest options seems to be using RasterExpressionEvaluator.
