FME used for copy and cut files
  • Jul 23, 2013 3:09 PM UTC
  • 9 replies
  • 187 views
is FME can be used to change name of file and folder and cut files in another?
If you prefer I don't want that FME read, i want to use it basically because i have 100 folders to tidy.
  • Jul 23, 2013 4:07 PM UTC
The FileCopy writer seems to be helpful.
Takashi
  • Jul 23, 2013 6:33 PM UTC
ok, i'll try it
thank you
  • Jul 24, 2013 12:54 PM UTC
I tried but i have this message:
File Copy Writer: Skipped 99 features that were missing source datasets
How to use file copy?
For example in source i have example.mif and i link it with file copy?
  • Jul 24, 2013 2:29 PM UTC
As a basic usage, send a feature which has the source file path as an attribute named 'filecopy_source_dataset' to the File Copy writer, then the source file will be copied in the specified directory. If you need to copy multiple files at once, the wild card (*) can be also used in the source file path string.
Takashi
  • Jul 24, 2013 3:38 PM UTC
You don't need to read the source data, just the source file path is necessary. Try first a simple workflow like this: Creator --> AttributeCreator     Name: filecopy_source_dataset     Value: C:\\<directory path>\\* --> File Copy Writer
Takashi
fmelizard
Forum|alt.badge.img+22
  • Jul 24, 2013 7:40 PM UTC
You can just use the directory and files reader > file copy writer.
  • Jul 25, 2013 12:10 PM UTC
Ok, it works
But FME is not the good software for doing this, it's too long.
FME is ok for transformation and extract data but no more.
  • Jul 26, 2013 4:57 AM UTC
The most part of file copy / move operations will be done by the OS, FME just provides the user interface to select source / destination file paths. I guess there are other reasons for having consumed long time.
Takashi
  • Jul 29, 2013 9:38 AM UTC
Yes you're right .
My computer having a task in the same time and i try on another and it's ok.
So it's possible, I was wrong about the time it takes
jy
