FME server webhooks: passing geojson polygon-coordinates in URL
  • Dec 7, 2021 4:38 PM UTC
  • 154 views
becchr
Forum|alt.badge.img+35
Hi, taking my first steps in the FME REST API and webhooks, and struggling on passing coordinates.
I published a simple workspace to FME server using the Geometry Pïcker as only parameter, the drawn polygon is noted in GeoJson, like:
{"type":"Polygon","coordinates":[[[3.732869,51.016178],[3.733537,51.016688],[3.734896,51.015998],[3.734086,51.015473],[3.732869,51.016178]]]}
 I created a webhook from this workspace, the URL preview shows the special characters should be encoded, like:
https://FMEserver/workspace.fmw?DrawnPolygon=%7B%22type%22%3A%22Polygon%22%2C%22coordinates%22%3A%5B%5B%5B3.732869%2C51.016178%5D%2C%5B3.733537%2C51.016688%5D%2C%5B3.734896%2C51.015998%5D%2C%5B3.734086%2C51.015473%5D%2C%5B3.732869%2C51.016178%5D%5D%5D%7D&opt_showresult=false&opt_servicemode=sync
but, when I GET-request through this URL, the workspace fails:
55	2021-12-7 17:05:35 | A JSON syntax error was found at line 1, column 2
56 2021-12-7 17:05:35 | Unexpected character: 't'. One of the following characters was expected: '"', '}'
57 2021-12-7 17:05:35 | The value of the import attribute '__GeometryReplacerTemp__' contained invalid JSON, and could not be parsed
58 2021-12-7 17:05:35 | The below feature caused the translation to be terminated
Looks like the polygon is not decoded correctly, as it is missing the "-characters?
62	2021-12-7 17:05:35 | Attribute(encoded: UTF-8) : `_DrawnPolygon' has value `{type:Polygon,coordinates:[[[3.732869,51.016178],[3.733537,51.016688],[3.734896,51.015998],[3.734086,51.015473],[3.732869,51.016178]]]}'
72 2021-12-7 17:05:35 | GeometryReplacer_<Rejected> (TeeFactory): GeometryReplacer_<Rejected>: Termination Message: 'GeometryReplacer output a <Rejected> feature. To continue translation when features are rejected, change 'Workspace Parameters' > Translation > 'Rejected Feature Handling' to 'Continue Translation''
Am I missing something? Should I encode/decode in a different way?
At the end, I hope to get input from a user through a custom webmap (ArcGIS Online and/or Leaflet), and use webhooks/RESTAPI to launch FME server workspaces, so there might be more convenient ways to do this, just trying to understand what goes wrong for now...
Best answer by hollyatsafe
Update: This issue has been resolved for FME 2022.0.
Hi @becchr​ ,
I'm sorry that you encountered this problem, I have been able to reproduce the issue you have described and I believe the problem is with how FME is storing the parameter value in the command line arguments when submitted via a Webhook. I have filed a bug to request this fix (internal reference: FMESERVER-17647) and will update this post when it is resolved.
In the meantime, you can workaround this issue in one of two ways:
1. In the Webhook URL replace the quote encoded reference (%22) with <quote> e.g.
https://FMEserver/workspace.fmw?DrawnPolygon=%7B<quote>type<quote>%3A<quote>Polygon<quote>%2C<quote>coordinates<quote>%3A%5B%5B%5B3.732869%2C51.016178%5D%2C%5B3.733537%2C51.016688%5D%2C%5B3.734896%2C51.015998%5D%2C%5B3.734086%2C51.015473%5D%2C%5B3.732869%2C51.016178%5D%5D%5D%7D&opt_showresult=false&opt_servicemode=sync
2. In the Workspace, fetch the parameter into an attribute and use a series of StringReplacer transformers to add quotes around type, polygon and coordinates before feeding the attribute into the GeometryReplacer.
  • Dec 20, 2021 2:29 PM UTC
Hi @becchr​ ,
arthur_bazin
Forum|alt.badge.img+19
  • Jul 28, 2025 12:01 PM UTC
Hi, i’m experiencing the same trouble with FME Flow 2025.1.0.1 - Build 25609 - win64.
Impossible to have the quoted value in FME.
The request part as send by the browser :
spatial_extent=%7B%22type%22%3A%22FeatureCollection%22%2C%22features%22%3A%5B%7B%22type%22%3A%22Feature%22%2C%22properties%22%3A%7B%7D%2C%22geometry%22%3A%7B%22coordinates%22%3A%5B%5B%5B7.050…
Into the log :
2025-7-28 13:42:46 | FME Configuration: Command line arguments are `fme' `my-script.fmw' `--FME_SERVER_REQUEST_URI' `http://xxx/my-script.fmw?opt_showresult=true&opt_servicemode=async&opt_responseformat=json&spatial_extent=%7B%22type%22%3A%22FeatureCollection%22%2C%22features%22%3A%5B%7B%22type%22%3A%22Feature%22%2C%22properties%22%3A%7B%7D%2C%22geometry%22%3A%7B%22coordinates%22%3A%5B%5B%5B7.050...'
`--spatial_extent' `{"type":"FeatureCollection","features":[{"type":"Feature","properties":{},"geometry":{"coordinates":[[[7.050….]]],"type":"Polygon"}}]}'
=> The quote are used into the command line invoked by the webhook
Into the workspace I’ve added a logguer with this parameter :
{type:FeatureCollection,features:[{type:Feature,properties:{},geometry:{coordinates:[[[7.050…
=> There isn’t any quote
The parameter is a text parameter
