FME_SERVER_SHAREDRESOURCE_TEMP in StringSoncatenator is not picked up as FME Server Parameter
  • Dec 19, 2017 2:05 PM UTC
  • 63 views
I am trying to concatenate a string for a path of a file that will be placed into:
fmeserver/resources#/FME_SHAREDRESOURCE_TEMP.
When I am into StringConcatenator I set up the string as a FME Server Parameter and click on OK and save the whole workspace. When I open the transformer again FME desktop sets the parameter as public and is highlighted in red (of course I do not have a public parameter called like that). Is there a way to prevent FME Desktop to take its own decision to change the setting of the transformer and pick up the user choice? I am working with a cloud instance of FME Server.
  • Dec 19, 2017 2:17 PM UTC
It should be enough to simply reference the following, without any prefix:
$(FME_SHAREDRESOURCE_TEMP)
This should return an absolute path.
jneujens
  • Dec 21, 2017 8:58 AM UTC
You just selected the FME_SHAREDRESOURCE_TEMP parameter, right? You did not create a new one with the same name?
When a workspace is started on FME Server, the FME_SHAREDRESOURCE_TEMP parameter is overwritten and will always point to the default location. If you want to store your outputs elsewhere, simply create a different output parameter.
