FME Server Log File for Job not found
  • Jun 26, 2019 2:10 PM UTC
  • 39 views
Hello,
I am new to FME Server, I have managed to publish a workspace form FME Desktop to FME Server. However when I try to run the workspace in FME Server I get a error:
This also happens when I try to follow the instructions with a test workspace from:
https://knowledge.safe.com/articles/22669/publish-a-workspace-to-fme-server-and-run-it.html
I have reinstalled FME Server already and it seems the directories of the logs are present in the installation folders. Can somebody explain what I am doing wrong?
Thank you.
Forum|alt.badge.img+63
Could be a number of things, there's some hints here: FME Server Troubleshooting: Resources, one thing that's not mentioned there that might also be affecting this is low disk space on the drive that holds your shared resources (which is also where the job logs end up), triggering aggressive cleanup tasks.
