FME hangs writing to Geodatabase SDE (Oracle). Why is it hanging?
  • Sep 20, 2016 8:05 PM UTC
  • 64 views
fmelizard
Forum|alt.badge.img+22
FME 64bit hangs reading or writing to Geodatabase SDE (Oracle).
I have ArcGIS 10.2.1 with background processing installed? When I run the workspace it hangs.
Why is it hanging?
The two last lines in the log file are:
INFORM|An ArcGIS license is already checked out. The product checked out is 'Advanced' 2016-09-19 INFORM|Installed ArcGIS version is '10.2.1'
steveatsafe
Forum|alt.badge.img+16
We've seen this a couple of times with different versions of FME 64bit and ArcGIS 10.2.1 with 64bit background processing installed. It typically involves ArcGIS 10.2 and Geodatabase that is on Oracle.
The problem isn't related to FME. It is due to missing patches for ArcGIS. To prove the problem is with ArcGIS only, you can isolate this to ArcGIS libraries by using arcpy and background processing to interact with the Geodatabase SDE (Oracle). This will present the problem with a hanging process.
The solution is to install the "Utility Patch series 6" software for the ArcGIS 10.2.1.
  • ArcGIS-1021-BGDT-OCPU-Patch (64bit Background Geoprocessing Oracle)
  • ArcGIS-1021-DT-OCPU-Patch (Desktop Oracle)
  • ArcGIS-1021-DT-UTU1-PatchB (Desktop Telecomm).
Once these are installed the ArcGIS 64bit background processing and the FME workspace will function correctly.
