FME Desktop 2016.1/2017 - SDE to ArcGIS Online - Writing to ArcGIS Online addResults error "Data is Null"
  • Mar 2, 2018 2:33 AM UTC
  • 107 views
We are performing an update to ArcGIS Online where the source data is from ESRI ArcGIS SDE database. This is the error that I encounter right now. I already tried to filter all fields using the NullAttributeMapper to replace Nulls with Empty String, but still I encounter this error.
What is meant by this error?
ArcGIS Online Feature Service Writer: 'addResults' error for a feature in 'Sewer Connection'. The error code from the server was '1000' and the message was: 'Data is Null. This method or property cannot be called on Null values.' ArcGIS Online Feature Service Writer: 3772 features successfully written to 'Sewer Connection', but the server rejected the 2 features in the last request due to errors. See warnings above. Aborting translation
lars_de_vries
Forum|alt.badge.img+10
I have seen this error before with ArcGIS. In most cases it is an error in reading the source data.
For what I can remember, the best solution was to replace the reader.
I hope this helps.
  • Mar 15, 2018 11:37 PM UTC
I hope this helps.
Thanks for your help. I will check how can I replace the reader.
