FME 2019 removes first and last letters of attributes
  • Nov 19, 2018 4:31 PM UTC
  • 63 views
Forum|alt.badge.img+4
Using Build #19136 of FME Workbench 2019, and the first and last letters are getting cut off for some reason. Source dataset is in ArcGIS Server 10.6 (running on Oracle 12c). Anyone else having this issue?
Best answer by markatsafe
This issue occurred in FME 2019 beta versions and should be addressed in the FME 2019 release or later versions of FME.
erik_jan
Forum|alt.badge.img+26
  • Nov 19, 2018 4:53 PM UTC
Definitely worth sending to www.safe.com/support
The sooner they are aware of these kind of issues, the better.
mark2atsafe
Forum|alt.badge.img+59
Please do. In the meantime I'll mention this to the development team and see if they are already aware of it.
mark2atsafe
I chatted with the developer and yes, it would be great if you could get in touch via the support team. The screenshot isn't enough for us to figure out what or even where the cause might lie. It would also be useful to know if this worked previously in, say 2018. Those formats haven't changed much recently, so I can't tell if it's a new problem or just one that was been hidden up until now.
Thanks, and apologies for any inconvenience it's causing.
  • Jun 22, 2020 6:14 PM UTC
