FME 2017: Writer FileGDB handle feature_type wrong
  • Aug 31, 2016 9:55 AM UTC
  • 74 views
tomfriedl
Forum|alt.badge.img+14
I'm insert:
  • Writer FileGDB (ArcObjects)
  • Set Feature Class to fme_feature_type
  • Duplicate the Output
In the navigator is only one Feature Type visible. In FME 2016 there are two. FME 2017 ignore the second output.
It's a bug?
mark2atsafe
Forum|alt.badge.img+59
Yes, it's almost certainly a bug and I can reproduce it. I'll file a problem report and let you know when it is fixed. Thanks for letting us know about this.
tomfriedl
  • Oct 28, 2016 11:43 AM UTC
In Build 17176 there are all Feature Types visible in the navigator. But the Feature Types have the same name: @Value(fme_feature_type). If I run the Workbench, I get the error:
Cannot have multiple factories with the same name. Multiple factories were assigned the name '_Value_m_esri_name__GEODATABASE_FILE_3_DirCreator'
It's not possible to rename the definition of the output?
  • Sep 26, 2019 10:47 PM UTC
I have the same problem in 2017.1 with FeatureWriter and Excel file.
Version: 2017.1.0.0 (20170731 - Build 17539 - WIN64)
Is there a workaround in 2017.1?
