Find attributes that meet the tester requirement
  • Feb 14, 2024 1:59 PM UTC
  • 10 replies
  • 247 views
marta.podsiad
Forum|alt.badge.img+12
HI,
I have a gdb with a lot of feature classes and I need FME to search thoroug the content of each layer and give me the list of all attributes from each layer that meets certain tester requirements. I was thinking of usint Attribute Validator but the content of the gdb will be changing hence adding attributes manually to each tester is going to be very time consuming. I need FME to search thorouhg the content of each layer saved in the gdb and give me the attributes
Best answer by hkingsbury
Okay, i’ve found a bug in the custom transformer; this is one we (Abley) have made.
I’ve updated it on the hub (now version 3). You can edit your existing instance like so...
If you edit the custom transformer (right click, edit)
Then open up the PythonCaller towards the right of the canvas
At the bottom in the Attributes to Expose box, make sure the values read:
_found{}.value _found{}.attribute
Forum|alt.badge.img+63
So just to be clear, do you want to test on attribute names or attribute values?
itsmatt
Forum|alt.badge.img+48
  • Feb 14, 2024 2:22 PM UTC
Hmm, maybe the AttributeExploder? This will create a new feature per attribute
so attributeName and attributeValue
You need to be a bit careful because this can create a tonne of features - but it should make it so you can just test the attribute value for whatever you want and you can easily get back the attirbute name and the feautre_type_name
dustin
Forum|alt.badge.img+36
  • Feb 14, 2024 2:35 PM UTC
Using the list option in the AttributeExploder might be a little more efficient than the feature option in this case.
A python solution might be the better solution here, but more clarification needed as @redgeographics mentioned.
nielsgerrits
Forum|alt.badge.img+67
Or save it as a list and use a listsearcher.
marta.podsiad
  • Feb 14, 2024 3:49 PM UTC
I need to test the values of attributes. The issue is that the name of the attributes may change
hkingsbury
Forum|alt.badge.img+73
  • Feb 14, 2024 9:19 PM UTC
Have a look at the AttributeValueSearcher :)
https://hub.safe.com/publishers/abley-limited/transformers/attributevaluesearcher
marta.podsiad
  • Feb 15, 2024 9:51 AM UTC
That is almost perfect. Is there a way to show only the attributes that meet the regex? For example I would like to see only MulipleLines as it meets the regex
hkingsbury
  • Feb 15, 2024 7:12 PM UTC
 The matched attributes are in a list called “_found{}”
marta.podsiad
  • Feb 17, 2024 5:18 PM UTC
thank you for the hint but the _found{} list is empty althouth the value is present in the Found port. What am I doing wrong?
hkingsbury
  • Feb 18, 2024 7:19 PM UTC
