Filtering out point cloud points which have too big Z difference compared to neighbor points
  • Oct 25, 2016 7:59 PM UTC
  • 75 views
geolassi
Forum|alt.badge.img+8
Hi group! I tried to find a way to filter out point cloud points, if they have too big Z difference compared to neighbor points. I couldn't find any transformer, which would do it. I could try using buffering a point, then find the points inside the buffer, then compare the Z with the buffered point and the inside points, but with 70GB of LAS files, I think it's too heavy. Are there any PointCloud related transformers, which could do that? Basically I'm filtering out noise and clouds or errors in Z.
Forum|alt.badge.img+63
What you're suggesting is basically what I did a long time ago (before the Point Cloud transformers were available)
Have you tried resampling?
@geolassi do you have any progress with your problem? I've got the same issue in my workspace.
