Fanout to xlsw
  • Feb 6, 2020 2:15 PM UTC
  • 54 views
nath
Forum|alt.badge.img+7
Im trying to write data to an xlsw writer where i want for each partner a seperate excel file with a sheet for each municipality.
So i tried to create a writer where i set my sheet name to an variabel attribute (gemeente) and then by the fanout option i tried the variabel attribute "gegevenspartner". But is doesn't work, what am i doing wrong?
Best answer by becchr
hi @nath, does it work if you put "@Value(Gegevenspartner).xlsx" as fanout expression? I think the extension is important
becchr
Forum|alt.badge.img+35
  • Feb 6, 2020 2:32 PM UTC
nath
  • Feb 6, 2020 2:40 PM UTC
Yes! Now it works! I had typed xlsx in the expression this instead of @value
