Export results of spatial filter in a text file
  • Jun 6, 2016 8:47 AM UTC
  • 45 views
Hello!
I use spatialfilter to know if 2 layers match each other. I would like to be informed if they match or not
and export the result in a text file such as: "6 entities of layer A doesn't match layer B".
I guess it's possible to do this with FME by including a SQL query but I don't know wich transformer or structur I should use?
Thanks for helping me
Hugo
Best answer by pratap
Hi @hgoroger,
Yes... After spatialfilter you have to place tester by using the attribute which you have defined under Predicate Attribute and filter the features. At this stage you will get all the features either passed/failed.
You can custom the results based on your requirement if you want only one line in txt file by the count then you have to use statistics calculator (for counting) and StringConcatenator to custom your message and connect to txt writer.
Hope this helps
Pratap
pratap
Forum|alt.badge.img+12
  • Jun 6, 2016 8:56 AM UTC
Hi @hgoroger,
Hope this helps
Pratap
  • Jun 6, 2016 9:02 AM UTC
Hi @hgoroger,
Hope this helps
Pratap
Thanks for this quick answer :)
