Esri ArcGIS Portal Reader
  • May 15, 2018 3:47 PM UTC
  • 8 replies
  • 204 views
bowlesg
Participant
I am trying to connect to a hosted feature service in our GIS Portal. I am receiving the following error:
..."Check your credentials and try again. The error code from the server was '400' and the message was: 'Unable to generate token.' A fatal error has occurred. Check the logfile above for details"...
I am using our fully qualified domain name with /sharing/rest/generateToken with our service account credentials.
Ideas??
Thanks,
--gary
rahulsharma
Forum|alt.badge.img+12
@bowlesg
Could you clarify if you are using Authentication type "Generate Token" or "NTLM"
bowlesg
Participant
  • Participant
  • May 15, 2018 6:48 PM UTC
Generate Token.
rahulsharma
It appears that ArcGIS portal might be set up to use NTLM Authentication. Try NTLM and use your Domain account
bowlesg
Participant
  • Participant
  • May 15, 2018 8:34 PM UTC
I tried the NTLM using domain account and received an error as well. We are setup using ADFS for our authentication to Portal with our AD.
rahulsharma
Hi @bowlesg
It appears this issue requires further investigation (investigating Logfiles). Would you please submit a report here https://www.safe.com/support/report-a-problem/
Thanks
  • Aug 1, 2018 1:22 PM UTC
Any other ideas on this question? I'm trying to connect to our internal portal and continue to receive the following error:
Failed to obtain any schemas from reader 'ARCGISPORTALFEATURES' from 1 datasets. This may be due to invalid datasets or format accessibility issues due to licensing, dependencies, or module loading.
Using Portal 10.6.1 and FME Desktop 2018.0.0.0
runneals
Forum|alt.badge.img+32
  • Aug 3, 2018 12:09 AM UTC
Is your service shared to the organization/everyone or private?
pingotech
  • Jun 3, 2019 8:16 PM UTC
@bowlesg, @rahulsharma
I was having this issue and because I wasn't sure how my IT department set up our ArcGIS portal, I initially assumed the authentication type was "Generate Token". By switch the authentication type to "NTLM" I was able to connect. Below shows an example of what worked for me:
