“Error running translation” error when output to geojson
  • Mar 27, 2020 8:00 PM UTC
  • 78 views
margaret_wei
I tried to read data from postgis reader and write to a geojson file. I only use two translators, a postgis reader and a geojson writer.
I encounter the "Error running translation." every time when feature number is about 40,000,000. I only use two translators, a postgis reader and a geojson writer. The translation seems to have no issue if the feature number is around 10,000,000. There was no other error message.
I also tried to turn on the debug log but still had the same error message.
I am using FME(R) 2019.2.1.0 (20191202 - Build 19813 - macosx).
Thank you!
  • Mar 30, 2020 7:38 AM UTC
Just out of curiosity, how useful is a GeoJSON file with 40+ million objects, and how humongous is it?
margaret_wei
I am using this geojson to create vector tiles for a map layer. The file with 35 million objects is around 30G.
  • Mar 30, 2020 3:26 PM UTC
Is it imperative that you have all the data in a single file, or would it be possible to split the data up over several files, let's say 10 million/file?
margaret_wei
Thank you for your suggestion. That's what I am doing now and it doesn't give me error.
