Error overwriting point dataset to ArcGIS Online - fmeobjects.FMELine cannot be converted to esriGeometryPoint
  • Jun 7, 2021 10:25 AM UTC
  • 218 views
I have a very simple point dataset which I am publishing to AGOL. It publishes fine first, but when trying to overwrite it, it gives the attached error (Fme_error1).
The error is strange as it mentioned FMELine, even though it is reading in a point dataset and writing to geometry type "arcgisonline_point".
I have tried changing the geometry type to multipoint but it still fails. Attached also is a picture of the workbench.
Any ideas please?
Forum|alt.badge.img+54
  • Jun 7, 2021 10:52 AM UTC
If you put in a geometryfilter, does everything exit via the point port?
  • Jun 7, 2021 3:37 PM UTC
Thanks @ebygomm​ , I think that's the problem. Geometry filter has returned a few line features, which I wasn't aware of. I will have to split these out into separate layers for AGOL.
