ECW Version 3 and FME
  • Mar 2, 2016 4:52 PM UTC
  • 5 replies
  • 69 views
I cant open a Version 3 ECW in FME Data Viewer. Error comes up and says I need new version of ECW SDK. I am using Desktop 2016 , and have downloaded the new SDK Version 5.1 from Intergraph. How do I leverage this in FME?
mark2atsafe
Forum|alt.badge.img+59
Sadly version 3 isn't supported by FME at this time. We already have an enhancement request filed with our developers. The reference number is PR#54009. I've added your details so you are contacted if and when it is implemented, and I'll see if I can increase the priority too.
Regards
Mark
Mark Ireland
Product Evangelist
Safe Software Inc.
  • Mar 3, 2016 8:34 AM UTC
I recently saw a presentation from someone who had found a workaround, temporarily writing the data to GeoTIFF (I think) and then using either a shutdown script or a SystemCaller to invoke command-line tools / arcpy to convert the GeoTIFF to ECW3, before deleting the temporary GeoTIFF.
Maybe that could be an option for you as well?
I used to do something similar before FME was able to write NetCDF files, it works rather well.
David
  • Mar 3, 2016 12:55 PM UTC
David
Actually, I'm wondering if it was the presentation from @jlutherthomas I was thinking about?
In reference to @david_r I've done work in FME writing to ECW v3 using the Hexagon GeoCompressor and running it using the SystemCaller. Once they've been written out I use the ER Viewer to check them before adding them into Apollo. They load in QGIS as well.
ER Viewer (free): http://www.softpedia.com/get/Multimedia/Graphic/Graphic-Viewers/ERDAS-ER-Viewer.shtml
xilef
  • May 7, 2018 9:50 PM UTC
Regards
Mark
Mark Ireland
Product Evangelist
Safe Software Inc.
@Mark2AtSafe, has the support for ECW version 3 been added in FME 2018?
Thanks,
Felix
