ECW Format v3 Writer error with coordinate system EPSG:2056 / EPSG:21780
  • Jan 6, 2020 4:28 PM UTC
  • 82 views
erido
Participant
With ECW v3 Writer I get the following error message:
ECW writer: An invalid parameter was used : date and projection setting are invalid.
The coordinate system used is EPSG:2056/EPSG:21780.
With the coordinate systems UTM / LL-WGS84 the ECW v3 Writer works correctly!
Tested with FME 2019.2.1.0 (Build 19813) WIN64 and FME 2020 Beta (Build 20153) WIN64.
palhermans
Forum|alt.badge.img+11
  • Jan 8, 2020 9:35 AM UTC
Hi @erido with 19813 I made a "Jpeg2ECW" workspace explitely setting EPSG:2056 with the coordinatesystemsetter. Maybe You should add the log and/or testdata for further troubleshooting. best pH
erido
Participant
  • Participant
  • Jan 9, 2020 1:51 AM UTC
Hi @palhermans thank you for your answer. Your proposal makes the same mistake. The input data is any GeoTIFF (.tif / .tfw). The .fmw and the log file with the error messages are in the appendix.
geotiff2ecw.fmw (39.6 kB)
geotiff2ecw.zip (3.1 kB)
brandonguo
Forum|alt.badge.img+7
  • Jun 17, 2020 1:19 AM UTC
In my case no matter it's writing into ECW 3 or 2, all gets the same error "invalid coordinates".
ekkischeffler
Hi, has this been resolved? I get the same error:
ECW writer: An invalid parameter was used : datum and projection setting are invalid.
Using EPSG:2193, writing ECW v3.
Works fine using ECW v2.
