dynamic writer for shapefile ZM
  • May 13, 2016 3:00 PM UTC
  • 107 views
I am using a dynamic writer to generate shapefiles. It is almost working fine except the geometries (Points, Lines and Polygons) are always generated with Z and M... even if the input (also over a dynamic reader) has no Z and M.
Any Idea how to solve this problem?? (Using FME Desktop 2015.0 Build 15253)
Best answer by takashi
Hi @lorans9, in FME 2015, you can set the Shape File Type parameter when adding the writer to the workspace.
nielsgerrits
Forum|alt.badge.img+67
I had a problem with shapefiles being ZM and not being able to copy features to a PostGIS layer in QGIS. 2DForcer and MeasureRemover solved my problem.
  • May 15, 2016 4:20 AM UTC
