DWG Writer - plan is exploded (arrows are not at the correct place)
  • Dec 31, 2021 4:17 PM UTC
  • 100 views
lgrie
Forum|alt.badge.img+8
Hello,
I am having trouble with an DWG plan containing arrows.
Workbench: Does changes in the model space and writes the modificated plan into a new DWG file. I am using a DGW styler just before the writer (I don' have selected more parameters).
Writer parameters: Preserve template paper space data: yes
Output (see image): Plan (green rectangle) and arrows (red rectangle) are seperated.
Does someone know why this occurs and has a handy solution?
Thank you!
caracadrian
Forum|alt.badge.img+23
  • Jan 2, 2022 1:38 PM UTC
What king of entities are the arrows? They can be from dimensions or leaders or polylines with different widths on each vertex or lines/polylines with arrow blocks on the ends...
Please supply some sample data.
lgrie
  • Jan 3, 2022 7:00 AM UTC
Hi @caracadrian​ ,
the arrows are leaders, the path type says straight leaders.
I attached some sample data of the arrows.
jovitaatsafe
Forum|alt.badge.img+11
@lgrie​, is there any reprojection happening in your workspace? It kind of reminds of this post where Dave suggested that they needed to reproject certain dimension attributes that have a text override separately using CsmapAttributeReprojectors: DWG to DWG - Reproject Dimension
lgrie
  • Jan 6, 2022 7:07 AM UTC
@jovitaatsafe​ No, not in the workspace itself. The projection is made by hand and the re-projected plan is then treated in a FME workbench.
Also the entity_type of the arrows is "leader".
