DWG to SHP
  • Feb 20, 2018 12:16 PM UTC
  • 7 replies
  • 138 views
Hello,
I am trying to make a Shape file from my DWG. I am trying to use only one layer from DWG because that is all I need. Basically I am trying to close all the polygons in that layer, and calculate their area and to write their area in shp. I am not getting a good result and I have no idea what could be the problem.
Also, I was wondering if I can get a result written in form of "P= "number" m2". Now I am getting this from screen shot.
Best answer by pratap
Kindly find the workspace attached.
Hope this helps
Pratap
acad2none.fmw
  • Feb 20, 2018 12:19 PM UTC
The first thing I'd try is a Snapper before the AreaBuilder.
In which way? I am not sure if I understood You. Thank You in advance!
  • Feb 20, 2018 12:32 PM UTC
Try the following:
  • Reader
  • Snapper (to make sure your lines connect properly)
  • AreaBuilder
I don't think you need the LineCloser.
pratap
Forum|alt.badge.img+12
  • Feb 20, 2018 12:38 PM UTC
Can you upload sample file
Pratap
Try the following:
  • Reader
  • AreaBuilder
It is not working like that, I have already tried it.
Pratap
11plan-parcelacije-ind-211111111.dwg
pratap
  • Feb 20, 2018 1:01 PM UTC
Hope this helps
Pratap
acad2none.fmw
