DWG layer description
  • Nov 28, 2018 2:34 PM UTC
  • 59 views
jatoxa
Forum|alt.badge.img+12
I can't seem to read layer descriptions from DWG files. I have tried different versions of FME, different reader settings and different DWG types with the same result.
It does seem to read a few of the layer descriptions but I have no idea why it would differentiate them as they seem identical when I open the files in AutoCAD.
Has anyone had the same issue?
Thanks!
danilo_fme
Forum|alt.badge.img+58
  • Nov 29, 2018 12:50 PM UTC
Hi @j2
Could you share us the file?
Thanks,
Danilo
gio
Forum|alt.badge.img+15
  • Nov 29, 2018 1:37 PM UTC
As I have no problem reading acad parameters, migth you please us with a offending dataset?
jatoxa
  • Nov 29, 2018 2:27 PM UTC
Hi @gio and @danilo_fme,
Thank you both for replying!
I happened to find an explanation for what I'm experiencing on the Autodesk forum. https://forums.autodesk.com/t5/civil-3d-forum/layer-manager-shows-layer-name-as-description-when-description/td-p/7289011
The descriptions were never there in the first place and FME remains flawless (almost;).
/Jacob
