Duplicates geometries DWG
  • Aug 30, 2018 3:38 AM UTC
  • 68 views
mr_fme
Forum|alt.badge.img+9
WHAT CAN I DO TO REMOVE DUPLICATED GEOMETRIES .DWG, I use the matcher but the geometries are not being detected as equal, they have differences of millimeters. Is there any other transformer?
itsmatt
Forum|alt.badge.img+48
  • Aug 30, 2018 8:28 AM UTC
You can try and use the CoordinateRounder first before matching. Also turn on Lenient geometry matching. I think the FME 2019 Beta version has an added better (more relaxed matching) for the Matcher (https://blog.safe.com/2018/08/fme-2019-beta-now-available-heres-whats-coming/) It might be worth giving that a go. I've had your problem before and it's not fun!
Forum|alt.badge.img+54
  • Aug 30, 2018 8:45 AM UTC
Have you tried setting a value for the Interior Vertex Tolerance in the matcher?
mr_fme
  • Aug 30, 2018 11:37 AM UTC
Yes, I tried, Interior and exterior vertex.
erik_jan
Forum|alt.badge.img+26
  • Aug 30, 2018 1:16 PM UTC
Another way of doing this would be using the CRCCalculator using the geometry only (remove the attributes) and then do a DuplicateFilter on the CRC attribute.
