Directory and File Pathnames to Isolate Folders
  • Aug 30, 2019 2:36 PM UTC
  • 56 views
Anybody have any success copying over a select group of folders using the Directory and File Pathnames to a filecopy transformer? I currently have it set up the same as described in https://knowledge.safe.com/questions/62005/copy-entire-folder-from-a-to-b-destination.html
where it successfully copies ALL the folders. (path filter is currently set to *) But I would like to set a regex in the Path Filter to only grab the folders I want.
example:
I have 9 folders with sporadic numbering/naming and only want folders 01,02,03 & 09.
01 – test
02 – test
03 – test group1
04 – test group2
05 – test
11 - test
12 - test
17 - test
09 - test
I tried
01 - test\\n02 - test\\n . . . but I can't seem to skip to the 09 folder?
Any thoughts
jdh
Forum|alt.badge.img+41
  • Aug 30, 2019 2:55 PM UTC
The readers all use glob patterns as filters, not regex.
You are better off doing something like 0* in the reader, and then a tester to keep only the ones you want, and then your fileCopy writer.
jdh
  • Aug 30, 2019 2:58 PM UTC
For an overview of glob see https://en.wikipedia.org/wiki/Glob_(programming)
Thanks JDH, worked great, is there anyway to convert the status to read-only while doing the transfer?
jdh
  • Aug 30, 2019 3:47 PM UTC
Not that I am aware of with the FileCopy Writer. If you use a FeatureWriter (set to FileCopy) you can use the summary port to trigger a SystemCaller to use a command line to make them read-only after the transfer.
In windows that would be: attrib +R "path to folder"\\* /s /d
