directory
  • Jun 7, 2019 11:51 AM UTC
  • 5 replies
  • 74 views
terezia86
can somebody help me with this error?
I did run the workspace successfuly and the datas are inside the folder.
When I want to inspect the writer, I become an error:
"Shape Reader: Failed to open dataset 'C:\\Data\\Adressen_Shape_3_BL\\Hessen\\Adressen_Deutschland.shp' which is neither an existing file nor directory"
I has never happened before.
danilo_fme
Forum|alt.badge.img+58
  • Jun 7, 2019 2:46 PM UTC
Hallo @tereziastredna
Please - could you check if this Writer was generated in Folder.
Danke,
Danilo
terezia86
  • Jun 7, 2019 2:58 PM UTC
Danke,
Danilo
thanks for reply!
danilo_fme
  • Jun 7, 2019 3:01 PM UTC
thanks for reply!
Thanks your png file.
Did you try to open with another Software?
Whats kind of version FME do you use?
jovitaatsafe
Forum|alt.badge.img+11
thanks for reply!
Hi @tereziastredna,
It looks to me from your folder screenshot that your shapefile is one folder deeper than where the writer inspector is searching for the file. I am seeing C:\\Data\\Adressen_Shape_3_BL\\Hessen\\Hessen\\Adressen_Deutschland.shp in your output folder, where there is another Hessen folder that contains all of the shapefiles.
When you get the error message from inspecting in the writer, if you are using FME 2019, it should give you a another chance to point the Inspector to your output files in a dialog like this:
Try pointing the Dataset path to your where your data is written and it should open from there. I'm curious how the second folder might have gotten in there though, so it'd be good to check the paths in the writer
terezia86
  • Jun 11, 2019 11:27 AM UTC
Hi @tereziastredna,
now I know what happened.
I set fanout to the name of this Attribute>so I get the ALSO folder with the name of area-what I wanted, just did not know that it will create one more folder. Thought it will be written into the folder with name- which I created...
