DGN writing custom linestyle
  • Jun 21, 2019 5:48 PM UTC
  • 5 replies
  • 126 views
Hi there,
I'm working on a workbench where I write DGN V8 data. I would want to use a custom linestyle from my seed file but it does not seem to work. What I do is I use an attributeCreator to create the attribute igds_style and I try to assign the custom linestyle value but I don't know what it's supposed to be. From the documentation, it is said that igds_style takes negative integer to represent custom linestyle.
My question would be how to know which number is assigned to my custom linestlye?
Also , do you have an other idea as to how to write my custom linestyle ?
Thanks in advance !
Forum|alt.badge.img+54
  • Jun 21, 2019 5:58 PM UTC
It seems to me there should be a better way, but the only way I found was to draw a line with the custom linestyle, read that line in and see what number had been assigned to the feature
  • Jun 21, 2019 6:52 PM UTC
How do you read it ?
Because when I draw a custom linestyle and I do 'info' on it, it display the name of the custom line for example : ( Dot ), but it does not show what number is assigned to the custom linestyle.
  • Jun 21, 2019 7:05 PM UTC
You need to read it into FME, and expose the igds attribute which is stored as the negative integer
  • Jun 21, 2019 7:09 PM UTC
Oh I see, gonna try next week when I get to work. Thank You for the responses
  • Jun 25, 2019 11:53 AM UTC
It works , thank you again
