DGN-file fail on reading elements by geometry
  • Jun 3, 2020 2:30 PM UTC
  • 147 views
I'm trying to read a .dgn-file with Bentley MicroStation Design (V8) reader. When i change parameter to group element by Geometry instead of Level names i get this error. Anyone know why i can read elements by level names but not with geometry?
2020-06-03 13:14:04| 15.0| 0.0|ERROR |f_0: Lookup table `DESIGNGEOMIgdsTypeToGroupLUT' doesn't contain key `igds_oriented_arc' or have a default value
Best answer by daveatsafe
We have corrected this issue in the beta for FME 2020.1 build 20572, which should be available for download in a few days.
daveatsafe
Forum|alt.badge.img+24
  • Jun 3, 2020 10:54 PM UTC
Hi @swecoselihm,
I believe the problem is due to a missing entry in one of FME's support files. Please copy the designGeom_read.fmi file inside the attached zip to your Program Files\\FME\\pipeline folder, then try the read by geometry again.
designGeom_read.zip
Hi @swecoselihm,
designGeom_read.zip
Thanks, that solved the problem!
daveatsafe
  • Jun 5, 2020 3:37 PM UTC
