Creating tables in eSDE?
  • Feb 23, 2024 3:47 PM UTC
  • 138 views
matthewb
Forum|alt.badge.img+12
I am reading data from a PostGIS table and writing to an ArcGIS eSDE, but I’m not able to create tables in the eSDE from FME, I can only write to tables created by ArcGIS Pro in the eSDE, is this normal?   I'm getting an ArcObjects error ‘-2147220655’, DBMS table not found.
nielsgerrits
Forum|alt.badge.img+67
My guess is you use a connection file with permissions to insert update delete, but not create tables? Do you use the same connection file as you use in Pro?
matthewb
  • Feb 23, 2024 8:02 PM UTC
I’m able to write to tables that already exist in the sde, just not create new tables in the sde using FME.  I have to create the table in ArcGIS Pro, then write to it.
nielsgerrits
Yes I understand. But do you use the same connectionfile when working from PRO and when using FME?
matthewb
  • Feb 26, 2024 2:04 PM UTC
Yes.  Same login and user.
