creating input and output port in pythoncaller?
  • Jun 8, 2015 8:20 AM UTC
  • 253 views
is it possible to creat differents input and output ports in a pythoncaller?
if it is, how could we do?
Thank you.
Yann
  • Jun 8, 2015 8:33 AM UTC
Hi
that isn't possible, I usually just create a new attribute in the Python code and then use an AttributeFilter or equivalent later on.
David
  • Jun 8, 2015 8:54 AM UTC
Thank you
jdh
Forum|alt.badge.img+41
  • Jun 8, 2015 2:29 PM UTC
When I want to mimic that, I wrap add the attribute(s) as Dave said, and wrap the python caller and Tester/AttributeFilter in a custom transformer and add as many outputs as desired.
  • Jun 11, 2015 8:49 AM UTC
thank you for your answers.
This question is solved but I don't know how to tag it "solved".
