Convert geodatabase to Shapfile
  • May 23, 2018 12:01 AM UTC
  • 49 views
boubcher
Forum|alt.badge.img+11
I am converting dataset from ESRI geodatabase to shapefile, but I am facing the domain problem
how could we expose the domain , I am still getting only the code
thanks
oscard
Forum|alt.badge.img+23
  • May 23, 2018 6:08 AM UTC
You have to check the "Resolve domains" option in the writer:
boubcher
  • May 24, 2018 6:14 AM UTC
Thanks
the problem is we are using the Esri Geodatabase (File Geodb Open API) Reader
and the option you specify require the ESRI license , is there any alternative ?
Thanks
oscard
  • May 24, 2018 6:25 AM UTC
Thanks
Thanks
I'm afraid you will need an ESRI license to be able to see the domains. I would be surpirsed if you could access the domains with the FIle Geodb Open API Reader.
If you need to read them just this time, I guess you could purchase a free trial ESRI license.
Sorry for not being able to help you farther.
