convert cell to point shape file
  • Jun 7, 2016 2:06 PM UTC
  • 44 views
I have many cells features in design file like hut_p, hut_t, hut_op, tank_p, tank_d etc. hut features are in level 1 and tank features in level 3. I want to convert them to shape file in two types of shape: hut and tank. I have done the same but my problem is that I want a field "type" in attribute of hut and in type field value i want value of feature, let me explain ::: for hut_p output for "type" value should be "permanent", for hut_t value should be "temporary".
similarly in the case of tank there will be one field in attribute table "type" which will have values : for tank_p value should be "perennial" and for tank_d value should be "dry".
Can anyone help me.
Regards
  • Jun 7, 2016 2:13 PM UTC
You can use the AttributeValueMapper to set the value of a new attribute (type) based on the value of an existing one (igds_cell_name).
